Renerte
PC Specification: i9-9900K GTX 1080 Ti 16GB
Action! doesn't start recording in "Game Mode"
Tue Aug 05, 2014 9:12 am
Hey,
when I try to record in "Game Mode" HUD appears, but pressing record button doesn't start capturing, and sometimes leaves empty AVI files in recording directory.
This problem happens on every game, and even when i use Action! Remote Control.
I use Windows 7 x64, nVidia GeForce GTX 460 (with latest drivers) - whole Dxdiag log: http://pastebin.com/MnRvubEH
Re: Action! doesn't start recording in "Game Mode"
Tue Aug 05, 2014 3:18 pm
Could you post a screenshot from your hotkey settings?
Renerte
Wed Aug 06, 2014 1:01 pm
Here you are:
I hope polish language is not a problem :P
Wed Aug 06, 2014 4:25 pm
Renerte wrote:Here you are:
Not at all. I thought there was some registry issue but there is not. Have you tried re-installing Action?
Renerte
Wed Aug 06, 2014 4:49 pm
Yes, I tried, but it didn't help.
I observed that Action! seems to try to record as main window sometimes shows timer for split second, stopping and as I said before sometimes leaving empty files empty files:
Maybe it will help locate the problem.
Thu Aug 07, 2014 3:15 pm
Renerte wrote:Yes, I tried, but it didn't help.
Do you record your videos into internal or external drive?
Renerte
Thu Aug 07, 2014 6:19 pm
I record to internal drive only.
Renerte
Tue Sep 30, 2014 10:47 am
Seems like neither you or Support have found reason of my problem. I give up. :cry: Maybe in a few years, when I'll get a new PC everything will be fixed. Still, if you have any tips, post them. I'll be checking this topic frequently.
Dobs
Sat Oct 18, 2014 10:49 pm
Have exact same issue.....very annoying to say the least.
ACTION GAMER
PC Specification: Windows 8.1 PRO , GPU GTX 770M , i7-4700
Thu Oct 30, 2014 12:01 am
i have same issue with action unfortunately developers can't fix this issues
