Tazorraxx
PC Specification: Intel i7-4510U, GT 820M, Windows 8.1
My fps is not working
Tue Aug 05, 2014 3:55 pm
I have just bought the mirillis action and I went on and set my settings but when I went on my game ( Minecraft ) my fps is still 1-10fps even though my framerate is set to 60fps. I tried to solve this problem but had no luck and I thought it was time to look for answers an I found a person with a similar situation and I was wondering if you could check it over for me and if it does not seem to work could you send me the answer by replying or by email : ryankarim21@hotmail.com. And here is the persons answer with a similar situation to me :
wmic process where name="Action.exe" CALL setpriority 16384
wmic process where name="Action_x64.bin" CALL setpriority 16384
wmic process where name="Action_x86.bin" CALL setpriority 16384
to create the Batch file. Open notebook. it is found by clicking on the windows orb. Then click all files and it is found in the accessories folder.
Open notebook and copy and paste the code into the notebook and click on the SAVE AS option. Once there, name the file anything you want, with "bat" at the end. example...actioncpuchange.bat. This part is important...under the file name, change file type to all. if you do not, it will not become a Batch file.
Your done. find the batch file you created and double click it and execute it. Should see FPS rock. Once I located my batch file...I stored it in my action folder and I made a desktop short cut.
Hope this helps everyone as much as it helped me. I was really starting to get mad. Thank you whoever you are that created this batch file. you deserve all the credit!!
USMChardcharger
