razrox
PC Specification: geforce 660
Audio Split into two?
Fri Aug 08, 2014 5:47 pm
I was using the Action demo and I was wondering if I could get two separate audio files when recording, one of myself on my microphone and one of the game i'm recording.
I only ask because I would like to edit the sound of the computer fan out and adjust other things without affecting the over all audio.
Any help would be great, if this is possible I will defiantly be buying Action!
Thanks
Re: Audio Split into two?
Mon Aug 11, 2014 5:49 pm
Yes, there is a feature called "Record microphone into separate audio track" which allows you to create two audio streams. One with system sounds and one with microphone audio.
