Joyverious
PC Specification: Sony Vaio, Windows 8.1 Intel Core i5
Everytime I open Action, my screen flickers then goes black
Thu Aug 14, 2014 6:08 am
Everytime I open Action, my screen flickers then goes black.
I tried using the newer version of action (Mirllis 1.19.2) The flickers and shut up of monitor doesn't happen on that version, However I purchased that version of action, and I just the 1.14.2 version.
Anyway, point is Mirllis action 1.14.2 is not working so well for me, every time i open it my screen flickers and my comp turns black, only way to have comp working again is by shutting down and restarting.
I will give a copy of my DxDiag: https://www.dropbox.com/s/qg2b033h4p837y1/DxDiag.txt
Please help, I've been searching all over and so far no fix!!
Joyverious
Re: Everytime I open Action, my screen flickers then goes bl
Thu Sep 18, 2014 5:18 am
IS ANYONE GOING TO HELP ME WITH THIS?!?!?
I love Action and its amazing performance but seriously its support service????
Help me, i've been searching for days now and everyone is ignoring this subject, i suppose there isn't a fix for this! WHY WOULDN'T THERE BE A FIX, THIS IS A BIG PROBLEM.
kevintrann
PC Specification: Windows 8.1 AMD FX-8320E Asus Radeon R9
Sun Oct 05, 2014 4:58 pm
I'm having the same problem also. Please help us :(
Thu Oct 09, 2014 3:45 pm
Joyverious wrote:IS ANYONE GOING TO HELP ME WITH THIS?!?!?
This is only a community forum, if you haven't received any feedback I recommend to contact the support team directly via support@mirillis.com.
InceptionFTW
PC Specification: Intel Core i5-3337U CPU @ 1.80GHz Win8.1
Sun Feb 15, 2015 1:19 am
I had the same problem... First make sure your not on custom screen region or desktop recording. It seems to work on application recording for me. You can also try uninstalling Mirillis Action by going to: Charms Bar -> Search -> Type in "Control Panel" -> Programs -> Uninstall a Program -> Find and Uninstall Action! -> Go to File Explorer -> In the search bar at the top right type in "REGEDIT" -> click on the broken cube looking thing that's called "regedit.exe" -> in the menu bar go to HKEY_CURRENT_USER -> Software -> Then delete the "Mirillis Folder" -> Close REGEDIT -> go back to file explorer -> go to your C Drive -> Program Files x86 (if you dont have program files x86 folder go to program files) -> delete Mirillis folder -> Then re-install Mirillis Action!!! Hopefully that will fix your problem!!! :D :lol:
Sincerely,
-Your friendly neighborhood InceptionFTW
herbzster
PC Specification: windows 8.1
Sat Apr 11, 2015 3:51 pm
I have tried uninstalling it countless times and to no avail my action still flickers then crashes it also doesn't show the frame rate in the top left of the screen and crashes my computer. I need a fix for this I just bought this and its already broken
lockeslay
PC Specification: i5, Geforce 9800GT, W8.1 (yea it sucks)
Sat Jul 18, 2015 10:43 pm
guys, i registered to this forum only to tell you that the fix for it is the dumbest thing ever... just click your action shortcut with the right button, go to properties, compatibility and set it to run as if in windows 7. done. action works perfectly...
so sorry for all of us who couldnt figure it out back then.... =[
PJD101
PC Specification: window 10
Sat May 13, 2017 6:39 am
i have the same problem help me please !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :evil: :evil: :evil: :evil: :evil:
Tue May 16, 2017 7:21 am
Try reinstalling your video drivers.
Technomancer
PC Specification: Windows 8.1, Nvidia 960 graphic card
Fri Jun 16, 2017 8:53 pm
I'm having this problem as well (it's a new issue for me, I've used Action for years with no problem before). I've tried reinstalling my video driver, uninstalling Action (including deleting the registry keys), launching in compatibility mode for Windows 8, and still I have this issue where opening Action causes my screen to flicker and then go black. How can I fix this?
