folkkfolk
PC Specification: CPU i7-3630QM VGA : GT 650m Windows 8.1
Suggestion and question :)
Fri Aug 15, 2014 5:53 am
I have a suggestion for Action! to be able to record and be able to spit sound from one program such as Skype from the system sound. For example, after you record a clip it separate into 3 audio tracks which is 1)Microphone sound 2)System Sound 3)Audio from Teamspeak 3 or Skype
I hope this would be add to Action! :)
And my question is if I buy Action! (Home use) can I possible use the same license when I reinstall Windows?
and the Action steam version same as Action! (Home use)? And i record video to upload to youtube which version do I need to buy or just buy the steam version?
Thanks you :)
Re: Suggestion and question :)
Tue Aug 19, 2014 5:18 pm
Yes, after re-installation you can re-use your serial number. Steam version is a commercial license.
