MomoLovesGaming
PC Specification: Windows 7
Audio Problems with Action!
Thu Aug 21, 2014 8:36 am
Hello! I recently bought Action! desktop recording software. :D SO far I love it! :) But the only problems I found were with the audio. Ok, so when I finish recording a video and I go to watch it the audio sounds choppy and sometimes the audio won't be in sync with the video. :? It can be very hard to understand. Can someone help me fix this problem because I really like this software. :cry:
Re: Audio Problems with Action!
Thu Aug 21, 2014 9:43 am
Does it occurs with AVI or MP4 videos?
MomoLovesGaming
Thu Aug 21, 2014 9:45 am
It happens with AVI videos and I dont know why... :?
Fri Aug 22, 2014 3:55 pm
MomoLovesGaming wrote:It happens with AVI videos and I dont know why... :?
Please try creating a test recording with 360p and 30 fps settings.
MomoLovesGaming
Fri Aug 22, 2014 5:36 pm
I made a test recording with the settings you said and its still out of sync and a little bit choppy. :(
Wed Aug 27, 2014 5:44 pm
Do you record into the same hard drive where your game is running?
MomoLovesGaming
Sat Aug 30, 2014 1:10 am
Yes I do. What can I do to fix these problems? Do I need to get a separate recorder? :?
Thu Sep 04, 2014 2:36 pm
In some cases when the hard drive gets overloaded there may be some issues with writing data to your hard drive. Do you have any possibility to record your video into another hard drive?
MomoLovesGaming
Fri Sep 05, 2014 8:20 pm
I'm guessing desktop computers have two hard drives but I really don't know. I am using a laptop so I only have one hard drive ( I think ). I have heard of external hard drives, will that work? :| Also, if an external hard drive works, then will I need to move all the files from Action! or just the ones that contain the videos?
Tue Sep 09, 2014 10:31 am
I don't think the external drive would work. USB speed may not be enough to keep the high bitrate data. What's your hdd RPM?
Return to “General Topics”
