CamJGaming
PC Specification: i7 4770k, GTX 770, Win 7 64-bit
Rust experimental not detected
Fri Aug 22, 2014 8:39 pm
Rust experimental isn't detected by Action! and you have to record the screen instead. Could you look into fixing this?
Re: Rust experimental not detected
Wed Aug 27, 2014 5:43 pm
Which DirectX version your game use?
CamJGaming
Wed Aug 27, 2014 7:35 pm
radi wrote:Which DirectX version your game use?
I am not sure. That would be something you should contact Garry (maker of the game) about.
