the9quad
PC Specification: i7 4930k, 3 X 290x's, Windows 10 64 Bit
Are you crashing? Try this.
Sat Aug 23, 2014 3:46 am
If you are crashing when you first start up, then delete the videos in your video folder, same with screen shots. If Action sees something in a format that it doesn't support correctly (video files in a mkv container for instance) it will instantly crash. Just something I learned today. :shock:
ActionUser2988
PC Specification: Windows 7 Nvidia GT 740
Re: Are you crashing? Try this.
Sun Aug 24, 2014 8:43 pm
I deleted the vids in the folder but it still wont work
