nathanhorny
PC Specification: i7 4700, gtx 765, 12gb ram
Mirillis doesn't show export options when pressing export
Sun Aug 24, 2014 10:25 am
Hi
The other day my mirillis was working perfectly and now when I try to export a video, the options that normally show up together with the export button don't appear, instead mirillis just turns dark and I can't click any mirillis button, when I press ALT+F4 it turns bright again and i can press all the buttons and record but I can't see the export settings so i can't export...
http://prntscr.com/4fx5qy
http://prntscr.com/4fx5vf
Re: Mirillis doesn't show export options when pressing expor
Wed Aug 27, 2014 5:30 pm
Did you have previously second monitor plugged to your PC? Probably the export window is out of your screen.
