saddlepiggy
PC Specification: Lenovo Z40 Model 59425584 Windows 8
Halfing Recording Length After Done Recording?
Sun Aug 24, 2014 10:43 pm
Hi, I have been having troubles with action. Here is my problem: I record a minecraft video for abou 24 min( the fps thing in the top right corner telling me), and when i go to edit it, it only says about 12 min in it, then i go in action and view it, and it says about 12 min. This has happened with a couple of videos, and the only vids i got were 3 of my first 5 or something(for various reasons that didnt have to do with your software).
saddlepiggy
Re: Halfing Recording Length After Done Recording?
Sun Aug 24, 2014 10:48 pm
also my pause button isnt working, but that might not be your fault. plz tell me how to fix if it does haveto do with Action
Wed Aug 27, 2014 5:29 pm
Do you record into AVI or MP4 format?
saddlepiggy
Sat Aug 30, 2014 12:47 am
mp4
HippoZoned
PC Specification: FX-6300, 8g ram, AMD2gb 7770 ghz edition
Sat Aug 30, 2014 1:10 am
mp4 is probably your problem, I was noticing when I recorded in mp4 my video would just stop rendering the record, I currently use mp4 amd app and I didnt run into an issure recording a 13+ min video today but I have the same issue in the plain MP4 format
Thu Sep 04, 2014 2:36 pm
Please check your CPU usage while recording your video into MP4. In some cases when the CPU is overloaded there is a problem with encoding your video. When the encoder fails the video will not be picked up anymore even if the HUD shows that it does. Some MP4 fixes will be delivered with next version which may solve this issue.
santtos
PC Specification: 7-4700HQ, nVidia GeForce 770M, Win 8.1
Mon Sep 08, 2014 10:01 pm
and the next version when will be? I just bought Action and have the same problem
