panamera
PC Specification: q9650 quad,asusp5qpro gtx660ti win8.1
nvidia gtx660ti
Thu Aug 28, 2014 10:43 pm
today i receive a new gtx660ti graphic card,i install splash pro,but crasch immediately,the drive for the video card is the latest one from nvidia...i am running win8.1,asus mthb p5qpro,q9650 quad 3gig,6gig corsair ddr2 800.Before i use the gt630 nvidia....no problem with splash pro...when i click the shortcut ...i receive the following error from windows
system32\nvspcap.dll is not designed to run on windows error status 0xc000012f,i think this is an issue between spla&shpro and the gtx660ti and his drivers....anyone have a solution?bcse splashpro is a very good player!my mail is debetueyvan@gmail.com thanks!
Phoenix
PC Specification: i7@3.7/32 GB RAM/Dual GeForce GTX 770M
Re: nvidia gtx660ti
Mon Sep 01, 2014 1:29 pm
Uninstall KB2879017 update.
Cumulative Security Update for IE 10 for Windows 8 x64 systems.
If you can't uninstall, restore to a previous point before the update.
Mark the update as hidden within Windows Update so it doesn't update again.
If you do not see that update in the Windows updates, then you need to try an older driver. Some drivers are known to cause this issue and this is NOT a Splash Player problem it's your system
Re: nvidia gtx660ti
Thu Sep 04, 2014 2:25 pm
This may be result of the newest Nvidia drivers which resulted with removing CUDA support. Please try re-installing your application and remove all registry entries associated with your Splash player. It should restore your Splash settings to default.
