I did it already, they got no idea what to do...Segus1992 wrote:Might want to post computer specs (camera, if you used one, CPU, GPU, Mobo, etc) to help them out with support.
Check this out first and you might have a quicker time getting help: http://forum.mirillis.com/viewtopic.php?f=36&t=34549
Does the same issue occurs when you re-size your brush while holding the Alt key and move your mouse?Kmak wrote:I noticed that when I use brackets ( "[" or "]") to resize brush size, Action! stops working. So I think that's the problem...
radi wrote:Does the same issue occurs when you re-size your brush while holding the Alt key and move your mouse?Kmak wrote:I noticed that when I use brackets ( "[" or "]") to resize brush size, Action! stops working. So I think that's the problem...
