CrazyAuburn
PC Specification: FX - 8320, R9 270, Windows 7
Exporting videos (Need help quick)
Fri Aug 29, 2014 8:43 pm
So I recently bought Mirillis Action! And I have been having a problem with it. The software is great and everything but the only thing that goes wrong is exporting videos. When I record my videos then export them most of them work but... 80% Of the time it only exports around 3 minutes of the video. My videos that i export are around 20 minutes long and I have the youtube file split off. This software is really the greatest but thats the only problem I have had so far. Thanks.
OS : Windows 7
Video card : AMD Radeon R9 270
Memory : 8 Gigs
Monitor resolution : 1600 X 900
Video editor : Sony Vegas Pro 13
Game problem : Surgeon Simulator
Video Type : AVI then Export into MP4 when done editing.
biggranny
PC Specification: Windows 7, AMD Phenom 965, r9 270x
Re: Exporting videos (Need help quick)
Fri Aug 29, 2014 9:00 pm
I don't seem to have the same issue you are but I am having an issue where everything I try uploading and it started happening recently a lot is my upload fails, and another error pops up saying: Connection with remote server failed! I would look around in the forums to try to find your problem and I will look to. Your specs look good to.
gioman97
PC Specification: intel core i7 7700k,GTX 1080,windows 10
Sun Aug 31, 2014 7:47 am
well you don't need to use Action! to get the job done you could just upload the raw file on youtube with a browser
CrazyAuburn
Mon Sep 01, 2014 4:40 am
I record them then export so it uploads and renders alot faster.
Thu Sep 04, 2014 2:26 pm
Do you have all recent video drivers installed for your AMD card?
CrazyAuburn
Sat Sep 13, 2014 10:21 pm
Yes i do and sorry for the late reply. I was on vacation.
Wed Sep 17, 2014 11:49 am
Please report your issue directly to our support team via support@mirillis.com.
