biggranny
PC Specification: Windows 7, AMD Phenom 965, r9 270x
Action! Upload Failed and connection with remote server fail
Fri Aug 29, 2014 8:54 pm
Everytime I try uploading a video it says upload failed, no matter what I try to upload, and it says the connection with remote server failed! It just started happening recently as well, Action! mostly used to work fine and it would have a failure every once in awhile, and now it's constant. Plus I've been looking into the forums and there sure is a lack of updates, and many people with crashes. I've seen this on another forum post that was a month or two old, and no solution. So am I screwed? Help will be greatly appreciated. I can give you guys specs if needed. I usually record with AVI and hardware acceleration and I've tried it without, still doing it and restarted my pc, still doing it. As I said before this all of the sudden is doing it to all of my videos. Although I did find a solution where if I lower the resolution it works, although this majorly affects the quality of my videos and that isn't what I want, I want 1080p, not dumbed down 720p. Also, I usually record at 60 FPS and upload to youtube. And another issue I have is when it tries to upload, it says upload failed and it says export complete, but it doesn't upload to youtube. What a waste of time trying to render videos and nothing works. ~Biggranny
Re: Action! Upload Failed and connection with remote server
Thu Sep 04, 2014 2:38 pm
Please check if you are not uploading your video into your Google account. Please go to your YouTube channel and then to advanced settings. You should be able to mark your channel as a default account. Once it's done you should be able to upload your video. Please also make sure that your firewall or anti-virus software does not block Action! Internet access.
