gege21
PC Specification: i7 965 Xtrem - GTX580 - W7 64 Pro
Action hit 100% CPU usage
Sun Aug 31, 2014 1:27 am
Hi all,
i7 965 Xtrem @ 3.2 Ghz stock (without Intel Quick S ability)
Graphic Card : Gigabyte GTX 580 Rev1 - 1.5 Go Vram
RAM : 12 Go Corsair domi. @ 1333 Mhz - Tri channel - 6x2 Go
OS W7 64 Pro.
Monitor res native : 1920x1080
Action v1.9.2
My issue : when I record in live streaming on TwitchTV, Action is set to 480p, 30 Fps, bitrate 700 Mbs upload (that is provided by testing on Speedtest.net for the ability of my internet connection), don't record the video on my HDD in the same time, tried to record with lower screen resolutions and with or without all CPU core, tried also with the region screen capture mode.... so after few minutes of live streaming playing my game ETS2, Action mirillis use 100% CPU usage. When that happen I can always play my game but it become with bad pictures with trembling effects and Action stop record my live stream. I can't stop Action by pressing the dedicated keyshortcut other than exiting the game and killing the action32.exe process in task manager.
Tried also in AVI and MP4 format : the bug 100% CPU usage is the same although in MP4 I can record in live Stream more time (45 mn about) before I get the bug again.
I don't want to purchase further more the live streaming capability key for few money through the Mirillis site at this time.
The free open source soft Open Broadcaster work very well and don't cause such bug.
Mirillis WAKE UP !!! and fix this bug please.
Re: Action hit 100% CPU usage
Thu Sep 04, 2014 2:33 pm
Unfortunately this issue occurs only with some users which makes it hard to reproduce. Next update will contain some fixes for MP4 recording which hopefully may fix also this issue.
