tonyproduction1
PC Specification: AMD-phenom(tm)IIx4965proc window7nospac
Microphone not working action
Tue Sep 02, 2014 1:08 pm
For some reason my microphone is not recording when I record video. I turned on the mic with the key and had it on always but it didn't work. I know it is on because in the sound tab in the computer I can see the sound change. I tested it on a website and it work. I used it in game and they can hear me. For some reason I can record my voice in the audio tag but not my video tab. Anyone here has a solution?
Re: Microphone not working action
Thu Sep 04, 2014 2:18 pm
Do you use record microphone into separate audio track feature?
tonyproduction1
Sat Sep 06, 2014 11:01 pm
My setting was record game sound and allow multi channel audio recording. It wasn't working even when I uncheck it.
Tue Sep 09, 2014 10:27 am
Could you post a screenshot from your Action! Audio Settings?
tonyproduction1
Wed Sep 24, 2014 7:38 pm
Here is my screenshot
Desktop 9-24-2014 3-30-01 PM-772.png (255.96 KiB) Viewed 15909 times
tonyproduction1
Wed Sep 24, 2014 7:45 pm
Its a little glitch, I will tell you what are my settings. Video recording AVI, 720p, frame rate 30, record system sound on, allow multi channel off, record on push down. Audio recording output file WAV, allow multi channel off, record silence off, record on push down.
Mon Sep 29, 2014 5:22 pm
Audio settings can be found in General Settings tab (last one).
tonyproduction1
Sun Oct 12, 2014 4:11 am
The screenshot for the game is too big. Like it is past the limit so I couldn't Upload it
tonyproduction1
Sun Oct 12, 2014 4:14 am
I will type my settings.
Microphone Settings
Microphone (high definition Audio Device) I tried the system default before
System Sounds
Audio device system default
Audio Balance
system sounds 20, microphone sound 80
bitrate default
tonyproduction1
Sun Oct 12, 2014 9:18 pm
I fixed it, I change the microphone from system default to microphone(high defintion) And I also uncheck the record on separate audio track.
