luisvidal41
PC Specification: Win 8.1
Action! records but does not save
Thu Sep 04, 2014 9:24 pm
I have Windows 8.1
Action 1.8.0
I used Action on Win 7 and all was OK
trying to use it on windows 8 i get this error
I updated to Win 8.1 But the error still :cry:
I Run it on W7 Compatibility Mode
Action! Opens and allows me to record but does not save the video
PD: Audio recorder y Screenshot Works :|
Re: Action! records but does not save
Fri Sep 05, 2014 8:48 am
Please update your Action! to 1.19.2 first.
luisvidal41
Fri Sep 05, 2014 6:49 pm
radi wrote:Please update your Action! to 1.19.2 first.
Updated but is exactly the same :|
1) The same error without compatibility mode
2)open on compatibility mode
3)look like recording but doesn't save :?
santtos
PC Specification: 7-4700HQ, nVidia GeForce 770M, Win 8.1
Mon Sep 08, 2014 9:56 pm
Just bought Action and have the same problem, windows 8.1 64 bit, Action 1.9.2.
Sometime record more then 1 or 2 hours or game play but save one 100-125 mb, other time don't save at all.
Tue Sep 09, 2014 10:32 am
One of our users recently fixed similar issue by running Action! in compatibility mode with Windows 8 instead of 8.1. Please try if it helps in your case.
luisvidal41
Tue Sep 09, 2014 11:31 pm
radi wrote:One of our users recently fixed similar issue by running Action! in compatibility mode with Windows 8 instead of 8.1. Please try if it helps in your case.
on windows 8 and 8.1 i get the error
so i suppose that is for the other user, but what about my ? :cry:
I tried uninstalling and deleting the registry but nothing happen.
Wed Sep 10, 2014 1:17 pm
Please report this issue to our support team via support@mirillis.com.
