Smily
PC Specification: intel i5 - AMD R9 Serie
Action! and Adobe Premier CC 2014 File Import
Tue Sep 09, 2014 1:15 pm
I am using Action! and record my game play using the mp4 (AMD APP) format with the best quality.
As soon as I try to import the recorded file into adobe premiere CC 2014 I get the message that the audio and video stream cannot be imported. With recorded AVI format everything is running fine but here the file size is much larger.
Does anybody have an solution?
Shouldn't adobe premiere support the codecs from Action! and the other way around?
Thanks in advance.
BR
Martin
Inserach
PC Specification: i5-3570k, HD7870, Windows 7 Home Premium
Re: Action! and Adobe Premier CC 2014 File Import
Wed Sep 10, 2014 7:15 pm
I use Adobe Prem Pro CC 2014 and have no issues importing Action! recorded mp4 files. I'm playing Mass Effect 3 atm and they work ok
Fri Sep 12, 2014 11:08 am
Could you please check if normal (non hardware accelerated) MP4 format can be properly imported to your editing software?
