hej
[BUG] Missing Audio in Recordings
Tue Sep 30, 2014 7:47 am
I make recordings of Planetside 2 using separate tracks without multi-channel recording.
None of my recordings pick up voice macros.
For example:
I kill a noob, I press v6 your "best is my worst!", I hear the audio. Then when I play video of this event I do not hear the audio "your best is my worst!".
I request that you please fix this issue so that recordings pick up all sound from the game.
Here is proof:
http://youtu.be/EVGgl7mF-Oc?t=3m31s
Re: [BUG] Missing Audio in Recordings
Tue Sep 30, 2014 12:50 pm
Do you use record multi-channel audio option?
hej
Thu Oct 02, 2014 9:57 pm
radi wrote:Do you use record multi-channel audio option?
hej wrote:I make recordings of Planetside 2 using separate tracks without multi-channel recording.
Furthermore, on videos with multi channel the sound exists in another separate channel.
