Acrodeminecraft
PC Specification: Windows 8.1; Intel(R) Atom(TM) 32bit
Launch pb
Sat Oct 04, 2014 10:27 am
Hello ...
First I'm French and I speak & write English with too many mistakes.
So, sorry for errors :roll:
I have download Action! 1.19.2 today and while I launch it. It doesn't work perpetually :
My config :
- Windows 8.1
- Intel© Atom™ CPU N450 @ 1.66 GHz 1.67GHz
- RAM DDR3 1,00 Go
- 32-bit architecture
Last edited by Acrodeminecraft on Tue Oct 21, 2014 3:25 pm, edited 2 times in total.
:D Thanks for your future reply :D
Re: Launch pb
Thu Oct 09, 2014 3:47 pm
Could you post your DxDiag report?
Acrodeminecraft
Re: Launch pb
Sun Oct 12, 2014 1:38 pm
I don't understand what did you talk about ?
Claunator
Re: Launch pb
Sun Oct 12, 2014 5:49 pm
Acrodeminecraft wrote:I don't understand what did you talk about ?
DxDiag shows info regarding ur PC.
How to run it: Open ur Start menu and type "dxdiag" into the search box, it should find it and display it ur results. Run it (i suggest as admin) and run a system diagnosis, it says something like "Run 64-bit diagnosis" or "Run diagnosis" or similar.
In case ur Start menu does not have a search box, dxdiag is located in C:\Windows\System32, not sure if it's the same on Win8/8.1 though.
Once it's done, find the .txt report and attach it to ur next post or edit ur previous one.
Acrodeminecraft
DxDiag reply
Tue Oct 21, 2014 3:14 pm
Sorry I'm late for the DXDiag but :
DxDiag.zip
(13.39 KiB) Downloaded 733 times
Good reading ;)
Acrodeminecraft
Re: Launch pb
Wed Nov 12, 2014 4:38 pm
UUUUPPPP .... :geek:
