Prodex
PC Specification: Intel Core i5-3570, GTX 770, Windows 8.1
Action! block the sound system
Tue Oct 07, 2014 2:13 pm
i love Action! but a few weeks ago the program block / mute the sound while recording. The inGame sound works perfectly but if i want to speak in TeamSpeak or want to record my voice with Audacity it dosn't work because Action! has muted everything (while recording only).
Is there any option to disable this "feature"?
Thanks in advance!
~ Prodex
Re: Action! block the sound system
Thu Oct 09, 2014 3:37 pm
Well, there is no possibility to even enable such feature because simply there is no such functionality in Action. Have you tried to re-instal Action! and cleaning its registry? It should restore the settings to default.
Prodex
Thu Oct 09, 2014 7:10 pm
radi wrote:Well, there is no possibility to even enable such feature because simply there is no such functionality in Action. Have you tried to re-instal Action! and cleaning its registry? It should restore the settings to default.
I did this already. Result: The same bug.
Fri Oct 10, 2014 3:50 pm
Please report this issue to our support team via support@mirillis.com.
