xxarthan
PC Specification: windows 8
Action shows launcher then freezes
Mon Oct 13, 2014 10:15 pm
I bought Action today and went to download and install It. As I launch it up the logo comes up and then it freezes.
I have tried. (keep in mind I do not know much about this type of thing)
uninstalling reinstalling
uninstalling going to regedit>user>software>mirillis>deleting it there restarting my computer and reinstalling it
there are other posts about this put since my computer is windows 8 when the Mirillis team member links the mirills@support when I go to click on it it just says that I don't have that app in the store
MrTra1tor
Re: Action shows launcher then freezes
Sat Oct 18, 2014 2:38 pm
Yeah, I used to have this issue a while back.
Move all your videos to a different folder and start up Action! and change to the new folder. That has been the fix for me 4/4 times.
I believe it happens if the PC crashes during a recording and Action! prioritizes it's own shutdown rather than cutting the recording off. Mostly this would just result in a corrupted video file, but it has a chance to corrupt the entire folder.
Mon Oct 20, 2014 5:47 pm
Do you experience any error message or it just hangs on loading screen?
Spacedflipper
PC Specification: H97M, Xeon E3-1231, R9 280, Windows 7
Fri Oct 31, 2014 5:59 am
As people with these problems seem to be really bad at staying on the forum to fix this. I also have this problem. The thing doesnt crash, it just hangs on the title thing.
