Skydive
PC Specification: i7-4960X EVGA Titan X HC (x2) Win10 x64
Action! 1.19.2.0 can't use CUDA for encoding
Thu Oct 23, 2014 5:10 pm
I have been using Action! a long time now. I have never had this problem before and I'm not sure if it's the latest version of Action! or possibly the latest NVIDIA drivers (or both) that could be causing this problem.
Under Export Settings, the check box and drop down menu for "Use hardware acceleration for video encoding" is greyed out and I cannot enable it.
I computer has the following hardware installed: Intel i7-4960X, 32GB 2133MHz Memory, (4x) EVGA GTX580 (4-Way SLI)
In the past I have always been able to use CUDA for video encoding, but for some reason now, it's not available. Is this a known problem? Is there a fix for this?
I will attach a screen capture of the Export Settings showing the option is not available.
Thank you!
Re: Action! 1.19.2.0 can't use CUDA for encoding
Thu Oct 30, 2014 4:44 pm
CUDA support has been removed in recent Nvidia drivers. If you would like to use it please reverse to your previous driver version.
In upcoming updates we are going to replace the CUDA with NVENC hardware acceleration.
Macro
PC Specification: Amd 965 BE,GTX 570,Windows 8.1 Prof
Fri Oct 31, 2014 11:04 pm
pretty hilarious. having a Graphicscard and a Pc that is easy capable to record this in this mode and the software don´t support it .in the previous versions it worked without trouble in all modes.
can´t activate 1080p or hardware acceleration OR MP4
I hope u guys fix this
btw .any workarround atm ?
