Valorek
PC Specification: ATI 8350 @4.5GHz,ATI R290,16GB,WIN 7 x64
Playback videos are not in sync with Audio
Sat Oct 25, 2014 1:11 am
Yes hello, I've been experiencing this issue for quite some time now and I have an idea of what is causing it but I am not having any luck and it's really frustrating. Title says all
Build:
Windows 7 64bit
FX-8350 CPU @ 4.5
MSI Nvidia 780TI @ 1.3
AMD Gaming Ram 16GB Quad channel
Things I've tried:
1.Ran directx test everything is 100% normal
2.Audio drivers are updated
3.Graphics card is updated
4.Windows NET framework and other misc updates are updated
5.Tried disabling antivirus, no dice
6.Tried reinstalling program directly from the mirilis site, no dice
7.Changed settings such as FPS record from 20-120 no difference
8.tried perfect video match mode and multi channel audio, nothing
9.Action! has current version
now heres my hunch, I used to own a standard 1080P 60hz asus monitor for awhile, in fact i had 3 for eyefinity but recently sold them to buy a new Nvidia Graphics card and G-Sync monitor at 144 hz I'm thinking mirilis does not support 144hz and that is the cause of the audio lag....
I did also dumb down my refresh frequency to 60hz and tried recording, playback vids still lag.. what is causing this?
I greatly appreciate your help
~Val
Valorek
Re: Playback videos are not in sync with Audio
Mon Oct 27, 2014 5:15 pm
I just do not understand, I don't know if it's the actual encoder itself or what. Does an overclocked graphics card mean anything perhaps?
Valorek
Tue Oct 28, 2014 11:35 pm
Alright well it appears I have a rather unique issue then
Thu Oct 30, 2014 2:49 pm
Does the same issue occurs on your standard 60Hz monitor?
Valorek
Fri Oct 31, 2014 12:48 am
No it does not, but I dumbed down the frequency as I said above to 60hz and it still does the same thing.
Valorek
Fri Oct 31, 2014 1:23 am
Well the encoder is saying that the playback videos are recording a bit rate of 324 Mbps is that too high?
