theminer3746
PC Specification: msi GE60 2PE with 16 GB of ram window8.1
Strange microphone issue
Wed Oct 29, 2014 4:44 pm
I'm using the following setting.
https://dl.dropboxusercontent.com/u/681 ... tled-1.jpg
https://dl.dropboxusercontent.com/u/681 ... tled-2.jpg
In the audio recording mode I can record my microphone and system sound, but in video recording mode I can only record my system sound. Have I need to export the video first before my mic sound come out?
P.S.By the way I'm currently using trial mode and I'll buy the full version as soon as I can fix this problem.
Re: Strange microphone issue
Thu Oct 30, 2014 9:45 am
You are using "Record microphone into separated audio track" feature. This feature creates an additional audio track in your video file. It does not create any additional file. While you are playing back your video file you will hear only one audio path at time. To switch between active audio track press "A".
theminer3746
Thu Oct 30, 2014 11:12 am
Thanks that's work.
