Macro
PC Specification: Amd 965 BE,GTX 570,Windows 8.1 Prof
So ,why is No Hardware acceleration possible ?
Sat Nov 01, 2014 10:15 am
Why is there no Hardware acceleration possible ?
So i have a Gtx 570 and it worked on previous versions in Action! so why i cant re-activate it ?
You cant record in 1080p or have the hardware acceleration on (.mp4).and your own pc is usually fully capable to do this.(it works in other programs)
btw:
CUDA is also disabled in the software,why ?
and is there any solution or workaround for this ?
and the program shows a strange behaviour:
if you add the cuda dlls manually.it says you should buy the legal version :shock:
if you delete it, it works nomal.
Re: So ,why is No Hardware acceleration possible ?
Sat Nov 01, 2014 10:34 am
CUDA has been removed in recent Nvidia drivers release. We will replace it with NVENC in upcoming release.
