Code: Select all
General
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 74.1 MiB
Duration : 3mn 14s
Overall bit rate : 3 193 Kbps
Video
Format : AVC
Format profile : Main@L3.0
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 3mn 14s
Bit rate : 3 060 Kbps
Maximum bit rate : 5 642 Kbps
Width : 720 pixels
Height : 576 pixels
[b]Display aspect ratio : 4:3[/b]
Frame rate mode : Constant
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.295
Stream size : 71.0 MiB (96%)
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 3mn 14s
Bit rate mode : Variable
Bit rate : 129 Kbps
Maximum bit rate : 147 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 3.00 MiB (4%)
