Claunator
Avast thinks Action 1.20.0 has a virus
Thu Nov 13, 2014 8:44 pm
This is something i didn't expect.. the download was nearly done and Avast came up saying it contains a virus... I re-downloaded it several times having Avast partially disabled, then i did a scan and it found nothing, weird.
Then i ran it as admin, and Avast brags again (same result)
I don't really know what this is about, is it a false alert?
Re: Avast thinks Action 1.20.0 has a virus
Fri Nov 14, 2014 10:02 am
Probably it's a false positive alert. action_launcher.exe is just a starting screen.
KyleL
PC Specification: windows 7
Sat Nov 15, 2014 7:19 am
I had the same problem with bitdefender https://www.virustotal.com/en/file/92a4 ... /analysis/
Sat Nov 15, 2014 11:35 am
I have made the same scan and the file is clear.
https://www.virustotal.com/en/file/edad ... /analysis/
KyleL
Sat Nov 15, 2014 7:10 pm
radi wrote:I have made the same scan and the file is clear.
You scanned a different file. I scanned action_launcher, you scanned action_logon
