kniff
PC Specification: i7 2600k@4.3Ghz/GTX 970 SLI/16GB RAM
1.20 + Nvenc
Sun Nov 16, 2014 3:35 pm
Happy that you added Nvenc support! It works great!
...But I would like to request more settings or at least the option for higher resolutions when recording. I realize this update was probably made with Kepler-era Nvidia GPU's in mind (770,780,780ti/Titan - 1440p60 max) but Maxwell (970/980) supports up to 2160p60!
For instance, if i record BF4 via Action! 1.20 through Nvenc on my LG UM95 (3440x1440) the recorded video is only 1920x804p60.
But If i do the same via Shadowplay the Video is 3440x1440p60.
Since you use the same Hardware encoder this should be no problem if you have the time to add the options, and like in the other topic you should be able to add a slider for bitrate as well since Nvenc is able to crank out
Thanks!
Re: 1.20 + Nvenc
Fri Nov 21, 2014 11:24 am
Thanks for your suggestion. I will let our developers now about this.
