kevinf63
PC Specification: i5 2500k, R9 290, 8GB 2133Mhz RAM
Recording with Two Web Cams Bug
Tue Nov 18, 2014 11:59 pm
This is a bit of a niche to be honest, but I'm recording with two web cams because of a flaw with Mixamo Face Plus. I wanted to demonstrate the facial motion capture software but unfortunately the PlayStation Eye camera can't stream to two applications at once.
I have two of these PlayStation Eye cameras handy, so I hooked them both up to counter this flaw in order to show my face and the characters face on screen at the same time. Unfortunately the second camera isn't showing up when going to select a second camera. I feel this might be down to the fact they are both called PlayStation Eye camera under device manager, and Action! only sees one camera. This probably could be solved by searching for the device hardware ID instead, or something along those lines.
Re: Recording with Two Web Cams Bug
Fri Nov 21, 2014 11:12 am
Please report this to our support team via support@mirillis.com.
