CJ2K
PC Specification: Win7 HP, 8gb, 12k mhz, Gf GTX 760
Recording Issues / Pest Or Cholera
Fri Nov 21, 2014 12:22 pm
Hey Guys!
Honestly, I'm a little bit pissed right now. After buying an Enterprise License, I'm only having trouble with Action (I know, it makes no sense, but it just started right after the test license was over). But first off, here are my specs:
OS: Windows 7 Home Premium 64 Bit
Video Card: Nvidia GTX 760
Memory: 8 GB
CPU: AMD Phenom II X4 940 3.00Ghz (12 GHz result, lil older one)
Monitor Resolution: 1920x1080
Video Editor: Vegas 12
Game Problem: EVERY Game
Video Type: AVI
Drivers: All drivers are up to date
So, I have 2 problems at the moment:
If I record in Gaming Mode, the files are to 90% damaged. I can't render them with Action! nor Vegas. It says that there is a Problem with the ficv-Codec (I can make you a picture or send you the error message, just need to make another fail-record) OR the video is completely async with the audio around the middle of the video (at the first part, everything is fine). I made around 10 recordings and only ONE worked!
Ok, that sucks. So I tried to record in screen mode. And then this happens: EVERY game I tried to record in this mode has the same problem. Everytime a loading screen (ingame) appears, Mirillis is going to record the desktop. I use 2 monitors, if this could be a hint.
Any ideas? Help appreciated! :D
Chris
Re: Recording Issues / Pest Or Cholera
Mon Nov 24, 2014 6:04 pm
Please report your issue directly to our support team via support@mirillis.com.
