CharlieBPlays
PC Specification: Windows 7 AMD Radeon HD 7560D
How to reinstall mirillis action please help!!!
Fri Nov 21, 2014 4:05 pm
Ok...So AVG decided to block and remove action! I couldn't start it up so I had to reinstall...well I tried to atleast...Then when I tried to reinstall It told me I had to buy it again! I want to know how to retrieve my serial key for my favourite recording software :( I have been using action for atleast 4 months with no problems :(PLEASE HELP!!!! :evil:
Re: How to reinstall mirillis action please help!!!
Mon Nov 24, 2014 6:01 pm
Please contact our support team about this issue directly via support@mirillis.com.
Kratzigel
PC Specification: AMD 2 FX 6300, Win 10, GTX 750TI
Contact: Twitter YouTube
Wed Nov 26, 2014 3:12 am
Little Tip,
u know that action not an virus is, than you can added the .exe or the folder to the exception.
When you reinstall your mirillis action than make this steps:
1. Open your AVG
2. Click right top on options
3. Advanded settings
4. Click on exception
5. Add exception
6. Select in the dropdown menu "folder", browse the install path from action and press ok.
7. That's it
