PlayFan
PC Specification: i7 2700k, GTX 970, Windows 8.1
CUDA workaround for Action!
Sun Nov 23, 2014 9:28 am
Hello guys !
As you may know, CUDA has been removed from Nvidia since the 340.52 update, but there's still an easy way to keep it even with updated drivers.
You just have to download this: http://puu.sh/d1tUo/392c9a1a14.zip and then drag the "Windows" folder in "C:\" (64 bit)
CUDA was pretty important to me, because it was the only way to resolve the audio desync for me.
Let me know if it worked for you ;)
Re: CUDA workaround for Action!
Mon Nov 24, 2014 5:49 pm
...or you can go with the NVENC acceleration ;)
PlayFan
Mon Nov 24, 2014 6:07 pm
Of course, but NVENC didnt resolve my audio desync issue unfortunately :?
GuidoFTO
PC Specification: CPU intel,NVIDIA GEFORCE GTX660, WIN 8.1
Mon Dec 29, 2014 6:42 pm
Before i couldnt record 1080p 60 FPS with AVI format because the image lagged a lot, now with this CUDA work around i can... and i get no audio desync... ITS GREAT ! But some times im still get frame drops
but i still get audio desync in 1080p 60 FPS with MP4 ENVEC, any tips?
