Rene78
PC Specification: Windows 7 (64)
Unidentified borderless window during Windows startup
Fri Nov 28, 2014 4:36 pm
Hello.
I would like to report a bug:
When I boot up Windows (7, 64bit) a small borderless window shows up in the top left corner of my screen. The only way to remove it, is to close down Mirillis Action, and start it up again. I'm using the option to have Action startup automatically with Windows. I don't think this happens if I uncheck this option and manually start Action.
I'll attach a picture of the offending window here.
Screenshot of the window opened in the top left corner of the screen, covering the "My Computer" icon.
Desktop 28-11-2014 17-03-45-938.jpg (13.14 KiB) Viewed 8800 times
Please have a fiddle with Action and make sure this is fixed.
Thank you.
René.
Rene78
Re: Unidentified borderless window during Windows startup
Fri Dec 05, 2014 3:48 pm
A full week and not a single reply. Not even from Mirillis telling me that they'll look into it.
Maybe I should have sent them a bug report by email or something.
Well I still hope that someone that can fix this has a look and takes action... (Get it? action... Oh you people are no fun.)
-Rene78
Mon Dec 08, 2014 1:54 pm
This is only a community forum. If you would like to get direct help or report an issue please do this via e-mail (support@mirillis.com).
Rene78
Mon Dec 08, 2014 3:27 pm
radi wrote:This is only a community forum. If you would like to get direct help or report an issue please do this via e-mail (support@mirillis.com).
Thank you. Done.
