Kilda
PC Specification: Win7, i5-3570@3.4GHz, AMD 7800 series
Unable to record mic via Zoom R24 audio interface
Sat Nov 29, 2014 12:15 pm
I have a Zoom R24 that provides a mic audio interface into my computer via USB.
I am able to record in-game video with mic and system sound using the AMD Gaming Evolved powered by Raptr. But I am unable to record my mic using Action! It appears to me that my mic is working fine.
From system sound point of view, I have the followings. I am able to record mic via my headset through the motherboard by the way.
My Action! setting is this.
And this as well.
I really would like to use my Zoom R24 to record in-game videos and would appreciate if you could show me how. Right now I have to continue using AMD Gaming Evolved because the mic from the headset does not sound good. And I purchased Action! thinking that it would work for me.
tonyproduction1
PC Specification: AMD-phenom(tm)IIx4965proc window7nospac
Re: Unable to record mic via Zoom R24 audio interface
Wed Dec 03, 2014 3:34 am
On the second photo, For the microphone setting turn the system default to the mic you are using. It should fix it.
Kilda
Wed Dec 03, 2014 4:14 am
tonyproduction1 wrote:On the second photo, For the microphone setting turn the system default to the mic you are using. It should fix it.
Thanks for your reply. I have also manually picked my USB line in instead of system default. It does not work as well.
