This used to work perfectly fine in 1.19, but in 1.20 and later it's bugged out.
Screenshot:
Please take a look and try to fix it. It can record my mic if I disable the seperate tracks option, but then the sound won't be balanced at all.
I'll try that when I get home. Sucks that it doesn't work like it used to :/psionicarrow wrote:I believe the player included with Action switches audio with the "A" key.
If you hear the mic audio and it seems fine then you'll have to extract the audio with an external program.
Directly from Action!.I see you're able to import .mp4 files into Premiere, are they the original files recorded by Action or have you re-encoded them to get that to work?
Ok, it worked!psionicarrow wrote:Action is actually recording the mic audio into another track in the same video file. Have you tried playing the file in a video player that let's you select different audio tracks? I believe the player included with Action switches audio with the "A" key.
Premiere Pro does not support additional audio tracks. You can export it using free software like VirtualDub to export it.MrTra1tor wrote:Ok, it worked!psionicarrow wrote:Action is actually recording the mic audio into another track in the same video file. Have you tried playing the file in a video player that let's you select different audio tracks? I believe the player included with Action switches audio with the "A" key.
Now, how do I extract the new audio track to Premiere? It still only shows one.
Try renaming the .mp4 file to .m4v and then import that, this works with Premiere Pro CC and gives both audio tracks.MrTra1tor wrote:Ok, it worked!psionicarrow wrote:Action is actually recording the mic audio into another track in the same video file. Have you tried playing the file in a video player that let's you select different audio tracks? I believe the player included with Action switches audio with the "A" key.
Thanks!radi wrote:Premiere Pro does not support additional audio tracks. You can export it using free software like VirtualDub to export it.MrTra1tor wrote:Ok, it worked!psionicarrow wrote:Action is actually recording the mic audio into another track in the same video file. Have you tried playing the file in a video player that let's you select different audio tracks? I believe the player included with Action switches audio with the "A" key.
I never saw the end of the clip, sorry :/ Anyway, thanks! This worked and is a lot easier than extracting the audio from a different software.psionicarrow wrote:Try renaming the .mp4 file to .m4v and then import that, this works with Premiere Pro CC and gives both audio tracks.MrTra1tor wrote:Ok, it worked!psionicarrow wrote:Action is actually recording the mic audio into another track in the same video file. Have you tried playing the file in a video player that let's you select different audio tracks? I believe the player included with Action switches audio with the "A" key.
Here's a video showing it working for me https://www.youtube.com/watch?v=UrDKgifnzFk
VirtualDub says that MP4 is not supported.radi wrote:Premiere Pro does not support additional audio tracks. You can export it using free software like VirtualDub to export it.MrTra1tor wrote:Ok, it worked!psionicarrow wrote:Action is actually recording the mic audio into another track in the same video file. Have you tried playing the file in a video player that let's you select different audio tracks? I believe the player included with Action switches audio with the "A" key.
