renaldy75
PC Specification: Intel 3930k, GTX 980, Window 7 pro
Action doesn't support MP4 1080p on recording
Sun Nov 30, 2014 8:17 pm
I would like to know when action will support MP4 1080p recording gameplay. YouTube doesn't support action AVI file
i want the file directly to YouTube without video editing just like FRAPS and SHADOWPLAY to able upload it at 60fps 1080p..it seen that Action it doesn't work me i just paid for the product
PlayingRisky
PC Specification: i7-3770K, GTX 970 SC, 8.1 Pro
Re: Action doesn't support MP4 1080p on recording
Tue Dec 02, 2014 12:13 am
As you have used Shadowplay, I'm going to assume you have an NVIDIA card. Try selecting MP4 (NVIDIA NVENC). You can record .mp4 files using your graphics card at full resolution, just like with Shadowplay. You may or may not have to install CUDA, but I don't know, I had it pre-installed. Hope this helps!
Tue Dec 02, 2014 4:31 pm
Action! supports 1080p recording only with AMD APP, Nvidia NVENC or Intel Quick Sync hardware acceleration.
Users browsing this forum: leopeck and 26 guests
