Heroman758
PC Specification: Windows 7
New Update Issue
Tue Dec 02, 2014 3:21 am
About half an hour ago, Action! notified me there was an update available. So I clicked the update button and the update began. But almost as soon as it began, there was an error writing a file called action_x86.dll and I cannot figure out how to get it to work. I tried installing without it, but I am unable to actually record anything. The physical recording part of the software appears to be missing (i.e. in the one file I can't download). I need help with this please as soon as possible!
Heroman758
Re: New Update Issue
Wed Dec 03, 2014 1:36 am
Ok, for anyone else who has this problem the fix I found for it is to reinstall Action! Make sure you have the installer .exe file and then uninstall action. MAKE SURE YOU DELETE ALL THE PROGRAM FILES FROM YOUR COMPUTER AS WELL! The reinstall/update issue was coming from an apparent programming issue where the old .dll file does not get removed and/or updated, so it causes a conflict. You will need to remove all the files before the installation or update is able to actually finish.
Fri Dec 05, 2014 3:23 pm
Thank you for sharing your solution with our community.
Users browsing this forum: No registered users and 44 guests
