CamJGaming
PC Specification: i7 4770k, GTX 770, Win 7 64-bit
NVENC low quality
Thu Dec 04, 2014 1:16 pm
I recorded DayZ for around 30 minutes and the output filesize was 5GB. But when viewing it, it looked awful. I'm recording NVENC 1080p 60FPS with mp4 bitrate at 100%, input range on 0-255, and video quality set to High. Anyone else experiencing the same thing
Claunator
Re: NVENC low quality
Thu Dec 04, 2014 5:17 pm
My Intel Quick Sync always does the same. The bitrates Action uses for hardware acceleration is ur problem here, the maximum bitrate is low compared to AVI. Compression rate might also be a reason bcs it happens while u're still recording.
It doesn't matter how high ur recording settings are, the result will always be more or less blurry, or otherwise "ugly", it's always been like that, at least i think.
The only thing u can do to improve it is to ask Mirillis to increase the maximum bitrate.
Fri Dec 05, 2014 3:18 pm
Could you post a video sample?
CamJGaming
Sun Dec 14, 2014 2:41 am
Sure I can post one.
Here's my settings
http://puu.sh/dtHxE/f4184dca61.jpg
http://puu.sh/dtHGx/9a5f1c4bdd.jpg
And here's the uploads, I also have a screenshots folder taken with Action while recording to compare. The VNENC (renamed the files to differentiate, they are NVENC) files are the worst ones, recorded Battlefield 4 and it didn't turn out great.
https://drive.google.com/folderview?id= ... sp=sharing
