powerofthetaco
PC Specification: windows 8.1
Auido Issues when recording
Fri Dec 05, 2014 8:56 pm
Hello, I record minecraft gameplay and I am having difficult getting my commentary to work. My settings are:
Recording mode: Game
File type: AVI
Framerate: 30
Video Size: 720p
Perfect Video Match Mode: On
Record System Sounds: On
Multi Channel Audio Recording: off
Record Microphone: Always
I keep hearing crackling or popping sounds. I know that it isn't my microphone because I never hear these in other programs and I use pop filter. I hope somebody can answer my question so I don't have to record audio in a different, harder, more confusing way. Thanks!
Re: Auido Issues when recording
Mon Dec 08, 2014 2:03 pm
Could you post a video sample?
powerofthetaco
Sat Dec 13, 2014 2:59 am
Mon Dec 15, 2014 4:30 pm
Thanks, that sounds like a performance issue. What settings do you use to capture your videos? What's your CPU usage during recording?
powerofthetaco
Fri Jan 02, 2015 4:08 pm
I don't know how to tell how much CPU Usage while recording. Sorry :( Also, I wanted to put screenshots of my settings, how do I do that?
P.S. So sorry I replied so late, I never got a email.
Tue Jan 06, 2015 2:25 pm
You can capture your screenshot by using Print Screen button on your keyboard and the paste your screenshot using Ctrl +V in MsPaint. CPU can be monitored using Task Manager under Performance tab.
powerofthetaco
Wed Jan 07, 2015 9:21 pm
These are my settings. I wasn't sure if you wanted to see my cpu usage while recording so I took a screenshot while recording.
Thanks again for helping me out.
powerofthetaco
Wed Jan 28, 2015 8:54 pm
I checked my task manager while recording and my cpu % was averaging around 40% and action % was averaging around 10%.
PS, when I record, my game drops to around 20-30 fps instead of the 40 I usually average. Most reviews said it caused no lag so...
Tolees
PC Specification: Windows 7 Ultimate 64 bit, 8320 FX
Thu Feb 05, 2015 11:39 pm
I have the same issue with the in game sound, every game sound have a crackling-popping every few seconds after the 1.21.0 update.
powerofthetaco
Sat Feb 21, 2015 12:37 pm
Have you fixed it?
