Re: Action! Speeds up video and audio at a different rate
Mon Dec 08, 2014 2:00 pm
Could you post a video sample of your issue?
hej
Sun Dec 21, 2014 7:54 am
I have same problem, happens maybe 1/10 times. Audio never syncs up, then it is very hard to sync up in video editor as you can't just drag them to the same size. Very annoying. Some files the video also does not show. Some files the audio does not play.
Primus Palus
PC Specification: 1075T, 270X 4GB, 16GB RAM, Win 7 64bit
Wed Dec 24, 2014 5:56 am
Same problem. Lots of sync issues.
Wed Dec 24, 2014 11:10 am
Primus Palus wrote:Same problem. Lots of sync issues.
That does not help in any way. Please post more information about your issue.
Primus Palus
Wed Dec 24, 2014 5:21 pm
Every video starts fine then a few seconds in the video it's ahead of the audio.
Primus Palus
Thu Dec 25, 2014 11:50 pm
Here is a video of my issues. I'm noticing now that the audio is trying to speed up to catch up with the video. Never noticed that before, it usually just lagged behind:
http://youtu.be/xvD64BNZNUA
At 1:25 you'll see the sync is way off to the gunfire.
Primus Palus
Sun Dec 28, 2014 9:57 am
Any ideas here? I see devs responding to other threads. Would love to get this working. Definitely better than Fraps.
Cheezbergurz
PC Specification: Windows 8.1
Sun Dec 28, 2014 3:06 pm
I am having this exact same problem.
I emailed support yesterday but haven't gotten a response.
I would really love to see this resolved so I can start recording again, because before the new version came out, everything worked perfectly.
saeed223
PC Specification: intel i5 ,gtx 740m ,win 8.1 .
Sun Dec 28, 2014 10:39 pm
same problem happening for everyone i hope that they are not ignoring as because i only bought action software yesterday and i had fraps before and only because it old and no one update it from so long .
TombstoneTWA
Wed Dec 31, 2014 12:36 am
I have solved the issue! If you open up ACTION, look for video framerate and turn it down to about 20-25. I've tested this myself and it fixes the problem! Might require further testing just to be sure but I do believe that is the issue. Hope this helps! :3
Users browsing this forum: No registered users and 53 guests
