Recent Kills
PC Specification: Windows 8.1
CS:GO
Mon Dec 08, 2014 1:12 am
Hello! I am having some trouble with your product(Action!). When i play a game called Counter Strike Global Offensive and record it, the audio and video are way offer. Suppose i shoot my gun i will hear the sound five seconds later in the recording. i tried all sorts of other games, they all worked fine while recording them. Please help me when you can! Peace! :D
Re: CS:GO
Mon Dec 08, 2014 1:56 pm
What settings do you use to capture your video?
Recent Kills
Re: CS:GO
Tue Dec 09, 2014 4:57 am
File format = AVI
Video Size = 1080p
Framerate = 30-50
record systems sounds = yes
allow multi channel audio recording = yes
Re: CS:GO
Tue Dec 09, 2014 9:18 am
Can you check if the same issue occur when you record into 360p/30fps?
Recent Kills
Re: CS:GO
Tue Dec 09, 2014 6:07 pm
I tried it. It works perfectly.
Re: CS:GO
Thu Dec 11, 2014 4:29 pm
Probably it's a performance issue. Can you post your DxDiag report?
Fragger
PC Specification: Win8.1 i7-2600k 16gbram Nvidia GTX480SLi
Re: CS:GO
Tue Dec 16, 2014 8:43 pm
I'm seeing the same issue with CS:GO. I just downloaded the Action! trial today and this is the only game i've tried but i can confirm that there are no audio sync issues at 30 FPS 1080p avi. But at anything above that shows greater and greater differences between audio and video in the output file.
In a ~30 second clip at 60fps my audio track was 29.xx seconds and my video track was only 23.xx seconds. I see differences in MPC, VLC, sony vegas renders (and timeline clearly calls out the differences) and in the Action! video player.
The difference in the sync progressively gets worse as the duration increases. off by a second at the start could be off by 4+ seconds at the end (again ~30 second clip). I'm not sure if the playback of the video is faster than it should be or if the video frames are just dropping during the recording.
i tried to record my desktop at 120FPS 1080p avi for 45 seconds and there were no sync issues.
