t3chn0vamp
PC Specification: ........
No option for brightness and constrast change? (SOLVED)
Tue Dec 06, 2011 1:11 pm
Hi guys!
I want to increase brightness and contrast of videos a little bit, cuz these are a bit dull by default, but i didn't find any option for this purpose in whole Splash Pro's settings.Mirillis team is there any option for this and if not then can you please add this?
Thanks!
P.J
Re: No option for brightness and constrast change???
Tue Dec 06, 2011 2:09 pm
Press the "O" key then enable Best Quality and you can change Brightness/Contrast.
t3chn0vamp
Wed Dec 07, 2011 9:47 am
P.J wrote:Press the "O" key then enable Best Quality and you can change Brightness/Contrast.
Thanks buddy. :D
Thu Mar 22, 2012 12:22 am
Thanks P.J for your help! :)
