GuilhermeG4Gold
PC Specification: CPU G620 | 4GB | NVIDIA GeForce GT 440
Starting on Action!
Mon Dec 15, 2014 12:31 pm
Hello i recently started the gameplays, and i have tested many trial versions of action! I really enjoyed
I plan to buy it through the steam soon.
My question
The latest versions of Action! do not work in a particular game, however the old version work, if I
purchase a license (buy on steam), i can use others version, I mean old versions?
Well, after buy i can explain better this ..
Thanks in advance
Translated by google
Re: Starting on Action!
Mon Dec 15, 2014 4:18 pm
What's the game name?
GuilhermeG4Gold
Tue Dec 16, 2014 11:11 am
radi wrote:What's the game name?
BlackShot Garena using Dx9 - AntiHack GameGuard
Well, what I think should be ...
when you open the game it automatically switches resolution to 1024
But how i already told i'm able to record in olds version of Action!,
even with little drop of fps using windows 8 enterprise.
Now I have bought but I can not record this game.
http://i.imgur.com/Lv5FwXp.png?1
Edit
After some tests I found the problem .. have 2 possibilities.
Anti hack is blocking Action! hook, then i need contact game development for get support, they have a bad support.
Anyway as I said older version of Action! hook work fine. So this may be a feedback for you analyze since I am
unable to recording with newest versions.
Thank you.
