cicciomaciste
PC Specification: windows 7
activation
Fri Dec 26, 2014 10:25 pm
purchased product but activation code is wrong ......... do ???
Re: activation
Fri Dec 26, 2014 11:04 pm
Make sure that your serial number is typed properly and you have filled all required fields. The easiest way to activate the software is to copy and paste your serial number into activation window. You will avoid any mistakes that may happen during manual retyping.
Users browsing this forum: No registered users and 48 guests
