GuidoFTO
PC Specification: CPU intel,NVIDIA GEFORCE GTX660, WIN 8.1
Game Audio Desync (bought action 2 days ago)
Sat Dec 27, 2014 1:20 pm
Hello i am having audio desync when recording games, it is wierd... sometimes it works and sometimes it has desync lets say 1/20 it works well, so yeah... Its really frustating and i have bought it only 2 days ago... i need it working. I record 60fps 1080p, i have tried it on games like Battlefield 4 and chivalry and i get desync in both of them, if i use AVI format, gameplay skips frames no idea why... i havent tried just mp4 because i need to record in more than 720p, so i use mp4 nvec (or something like that) to get 1080p but i get audio desync.
My GPU its a NVIDIA GeForce GTX 660 i use windows 8.1 and i have an Intel CPU
I have also noticed that when recording in 1080 p 60fps the games work really smooth and good but every 2-3 minutes the game gets a bit of lag for like 1 second, not a big deal but maybe it will help you recognize the problem with the desync.
If it helps... I use Alesis USB 4 mixer plugged with USB into the PC and then i plug a studio microphone (T-Bone 1100) into the mixer.
I need some help ASAP, i need to get this fixed ! Regards
EDIT: o have found out that this problem wont occur when recording 720p 60FPS or 1080p at 50FPS... But it always happens when i record 1080p at 60FPS, i am starting to think i maight need a better graphic card? Tips and opinions are appreciated!
vision
PC Specification: AMD 8350, MSi r9 290x, Windows8.1
Re: Game Audio Desync (bought action 2 days ago)
Mon Dec 29, 2014 10:18 pm
I have the same issue and i cant find any help here i have a video in youtube, tell me if u have the same problem!
https://www.youtube.com/watch?v=XGPoIhkn-3Q :(
Primus Palus
PC Specification: 1075T, 270X 4GB, 16GB RAM, Win 7 64bit
Mon Dec 29, 2014 10:41 pm
You don't need another graphics card... it's happening to a lot of us. Here's a thread about it:
http://forum.mirillis.com/viewtopic.php?f=36&t=35250
There are a few others on the forums too. I'll change mine to 50fps and see if it fixes for me. But at 1920 x 1080 at 60fps, I get that desync.
Even if I can fix the desync problem, I still have my microphone problem explained here:
http://forum.mirillis.com/viewtopic.php?f=36&t=35569
saeed223
PC Specification: intel i5 ,gtx 740m ,win 8.1 .
Tue Dec 30, 2014 1:16 am
i had same problem but i discoverd from where the problem comes and i have the solution , change the microphone usb port to usb 2 port only and it will be fixed .
usb 3 port cause lag and problems for some microphones .
i hope it works for you.
Primus Palus
Tue Dec 30, 2014 1:48 am
saeed223 wrote:i had same problem but i discoverd from where the problem comes and i have the solution , change the microphone usb port to usb 2 port only and it will be fixed .
Mine is a 3.5mm plug... not USB. So that doesn't fix that problem for the rest of us.
hej
Wed Dec 31, 2014 3:57 am
Audio desync has been going on for a few months, the issue and solution is on developer end. I've heard that reverting to version 1.73 fixes the problems but haven't found a legal download link for it to test. See what you can do about getting a refund, its pretty bs that you buy a software and it doesn't work the first day and you're expected to wait for a fix that hasn't come in months.
edit: found link, was searching wrong: http://download.mirillis.com/files/acti ... _setup.exe
Primus Palus
Wed Dec 31, 2014 4:00 am
hej wrote:Audio desync has been going on for a few months, the issue and solution is on developer end. I've heard that reverting to version 1.73 fixes the problems but haven't found a legal download link for it to test. See what you can do about getting a refund, its pretty bs that you buy a software and it doesn't work the first day and you're expected to wait for a fix that hasn't come in months.
I think it's silly that it's being discussed in so many threads and not a single solution yet other than to not use 1920 x 1080 at 60fps. I'm having a mic problem too and so far the only response has been that it must be TeamSpeaks fault, when that's not even running in the video.
hej
Wed Dec 31, 2014 4:11 am
Primus Palus wrote:I think it's silly that it's being discussed in so many threads and not a single solution yet other than to not use 1920 x 1080 at 60fps. I'm having a mic problem too and so far the only response has been that it must be TeamSpeaks fault, when that's not even running in the video.
It is so silly that I had to go and buy a different program while already owning action. There's one feature I miss, that is ctrl+del quick delete, so its a race between that software adding the feature and mirillis fixing their program until I get a proper recording experience.
Mirillis is trading their reputation for the ability to charge existing customers $5/month by continuing along this development path.
Tue Jan 06, 2015 2:30 pm
We are gathering all the synchronization issues here: http://forum.mirillis.com/viewtopic.php?f=36&t=35865
