Sheep
PC Specification: Aspire E1-532, Windows 7
Exporting problems.
Thu Jan 01, 2015 11:10 pm
Hello I'm new to the forums and Action itself I think I know what I am doing for the most part but whenever I try to export my videos to avi, it says it's exporting to mp4 and also it stays at 0%, no matter what settings I have it on and what video I try to export.
Stays at 0%
Sheep
Re: Exporting problems.
Mon Jan 05, 2015 12:41 pm
bump
Tue Jan 06, 2015 2:17 pm
Please disable the hardware acceleration in Export Settings and see if that helps.
Sheep
Fri Jan 09, 2015 12:32 pm
radi wrote:Please disable the hardware acceleration in Export Settings and see if that helps.
Well, the video has actually started exporting. Thank you.
I will come back and report the quality of the video after it is done :)
EDIT: It worked!!! Thank you very much! The video seems to be fine, no lag and 1080p quality :D
