Choppy
PC Specification: Radeon R7 250 running Windows 8.1
Issue with Exporting
Fri Jan 02, 2015 2:21 am
Whenever I try to export a video and occasionally when I open up Action!, it crashes/freezes my computer. The only way to reset from this state is by hard resetting using the power button. I have no idea what causes it to happen and would like to fix it ASAP.
PC Specs:
GPU: Radeon R7 250
CPU: AMD Vishera 8 Core
RAM: 16 GB DDR3 RAM
PSU: EVGA 500w
HDD: Toshiba 2TB
Re: Issue with Exporting
Tue Jan 06, 2015 2:25 pm
Check if you are using latest drivers for your video card.
Choppy
Mon Jan 12, 2015 1:28 am
I just updated it and it still freezes, it also freezes when it's loading up Action and I switch to another tab.
