Cassutt Pilot
PC Specification: Win 7
Action disables Logitech K810 bluetooth keyboard / X-Plane
Sun Jan 04, 2015 7:28 pm
Latest and greatest pay ware "Action" disables my keyboard while recording. Using Print Scr as the record hot key and it works but keys used by X-Plane 10, 64bit doesn't work while Action is active. All USB and mouse inputs function normally. Shut down Action and I get keyboard control back. Any ideas???
Win 7 (64 bit), ASUS Maximus VII Formula MB, i7-4790K @ 4ghz, 16GB Corsair Vengence Pro series DDR# @ 1866mhz, ASUS Striker Platinum GTX 760 4GB DDR5, Samsung SSD 840EVO 500GB
Re: Action disables Logitech K810 bluetooth keyboard / X-Pla
Tue Jan 06, 2015 2:21 pm
Does your keyboard comes with additional software?
Cassutt Pilot
Thu Jan 08, 2015 11:04 pm
Only for remapping, not using it. Just tested the problem with a Microsoft ps2 keyboard and experienced the same problem.
Game mode doesn't function at all
Active screen will only function if I run X-plane in a window
Active desktop will record and stop with the keyboard but lose keyboard control for X-plane
All USB input works as they should (throttle, joystick and buttons
atcon
PC Specification: GPU R9-280X 3GD5, Win7
Mon Sep 21, 2015 4:23 pm
I encountered the same problem. Action! just doesn't work in full screen mode of X-plane 10 64bit.
Does mirillis have a solution for this issue? I purchased Action! is to record my X-plane video, but only work in windowed mode so far. That's really a pity.
Users browsing this forum: No registered users and 53 guests
