Downthehollow
PC Specification: Inter Xeon E3-1230 v3, windows 7,
My gameplay says FAILED TO INPUT FILE.
Mon Jan 05, 2015 7:25 pm
PC specs.
windows 7
Intel Xeon CPU E3-1230 v3 @3.30 GHz
16 GB ram
resolution: 1280X720
I forgot what graphics card but i can assure you that it is good. and it's an NVIDIA
Editing software: adobe premiere pro
game: left 4 dead 2, Dust, and The waking mars
And i feel like that's all that should matter when
When i hover over the file instead of it being a screenshot of the gameplay it's just a loading screen and in the folder it just has the vlc player logo. when i try to open it with quicktime it says it cannot read that file. When i try to open it through action it says Failed to open input file. And when i try to upload it to adobe it just crashes....so what's going on and are my files recoverable? Because i have a couple hours of gameplay that i just lost if it isn't.
Downthehollow
Re: My gameplay says FAILED TO INPUT FILE.
Mon Jan 05, 2015 11:22 pm
it turns out that if the file size is too large and if i abruptly end the recording it just crashes. My bad.
